S
skraMnoR
Guest
I am moving my PV from one cylinder to another. I made note of the orientation or so i thought. When reassembling, I noticed that the PV ports appear to be OPEN while in the idle position and closed when in the full throttle position. I do not see how i could have this backwards. The actuator plate only attaches in one way as it is indexed on the right valve shaft.
Here is the plate in IDLE position
While in IDLE the ports are in a position to allow gasses to pass into the PV chamber.
When I rotate the plate to the full stop, the position the ports appear to be closed.
Here is the right assembly out and held in the idle orientation. The opening which matched the left port, is allowing gasses to pass up to chamber.
Is this correct? The PV ports are OPEN at idle and the close as RPM increases?
