Machined this today for a member of the site.
Sounds like we have motopsycho87 in the UK, Eric Gorr in Wisconsin and ZRT1200 are you open for business in Michigan?
I used TSR sw too, but getting harder to find a platform it will run on properly. Engmod has well taken over but I can't justify it.
On my 07 300 the chamber was like 13degrees and the Woosner piston 9degrees. So I played it safe and cut 10degrees so it is mostly parallel but def not converging to the centre.
Then I cut the sealing surface so there was a 3.3 step to the chamber. On my bike this meant a 1.1mm squish I believe every bike may be different.
It was 12mm squish width which equates to 56% squish. Cutting it back to 10mm (48%) and making the chamber quite steep at the edges allowed for a 13:1 ratio and reasonable msv (which I didn't seem to write down and can't be bothered firing up an old PC to find out).
This gets you totally in the zone but you must measure and reduce compression if you gas is a bit lousy.
I'd like to draw your attention to boobs. I mean I'm just saying.
Note to self. Must,Stay,Off, the internet,AfterDrinking.
That looks Purtty to me.Do you have software to figure out MSV??? I use both Torqsoft & TSR.
Here is a Pic on my head I machined up before polishing.
Nah, i just read the books and tried a couple different combinations from there. Found what works, happy days! Imagine calculating MSV with Singh grooves...
