I assume the hose clamps.. As John said. A small flat blade and pry the edge up where it clips on. It'll pop undone easily. Using some pliars you can reuse them.
Thanks guys
Anything else I should bear in mind when swapping the rads out?
Have ordered left and right non OEM. Was planning to replace both
Then look at getting the damaged one repaired.
