Rebound, top or bottom on marzocchi 48
Different model Gassers come with different forks. The suspension has also changed a few times over the years.
Always go with the manufacturer on these specs.
In general, the location of the compression adjuster is to do with the design of the fork and where the base valve is positioned internally. On closed chamber forks such as the Marzocchi 48mm with PFP it is on the top. On the open chamber such as the 45mm USDs it is the bottom.
Every bike I have owned with adjusters have been marked on the compression be it on the top or bottom with COM. but I have not
had Marzocchi forks
In other words most of the gasgas owners out there have it wrong, including myself since gasgas are useless in wrighting manuals :mad:
useless at writing...
Some things are lost in translation, some are just poorly proofed. This site is your user manual.
The comp and rebound adjustment got me too! The zoke manual is pretty good if you take the time to read and understand it.
