Could air in the slave cylinder cause not having installed gap?
I've checked the clutch pack 7 friction 8 steel and the thinner 1mm steel first. Other steel are 1.5 mm I've never had a good clutch over ride last week I took off the slave cylinder and turned out the little allen adjuster to far and a small drop of oil came out. During last weekends ride the clutch got worse. Did not disengage when idle I had to use the clutch lever to get some disengagement. With the clutch lever pulled it felt like it should be without the lever pulled. Could this be cause because of air in the slave cylinder? I check everything else this evening and it is all as should be.
The recluse was installed by a shop who never started the bike. (They probably started work to late and I had to pickup the bike for a race) I did find air bubbles in the master the first race weekend when I pulled the lever with the cap off. Will try bleeding the clutch slave and master according the recluse instructions as I'm out of other ideas and this is the job that I was looking least forward too.
