Just to be perfectly clear before I start reefing on stuff. The clutch basket nut is regular thread and nut over the primary gear on the clutch side of the crank is reverse, correct?
Thanks. DO you use a penny in the gears or some other method to hold them still? I have used a drift through the crank but I hate to load everything to remove nuts.
