I'm dealing with the broken water pump impeller issue. Mark at Gofasters is sending the parts (Thanks Mark). I want to remove the whole WP assembly (WP housing and the portion of the case that surrounds the clutch) - I'll call it the clutch/WP housing portion of the engine case.
I've removed all bolts from WP cover and the clutch/WP housing. I can pull the rear portion of the housing from the center case but the front of the housing is resisting removal. I small gap has opened but I cannot completely remove it.
I'm guessing that there is some corrosion around a index pin and I am resisting the urge to pry it off. I have not missed removing any bolts like I usually find when I have this kind of problem
Am I missing anything?
Rick
2012 GG 300
Rick
2012 GG 300
