Sachs shock ec 300 2010 crossover?
Ohlins 888 is for gasgas only should be able to find one one eBay make sure it's for a 07-11
Yerpp.. 888 or TTX from these years will fit.. Note that the exception is the 2011 Racing and Nambo/Cerventez models; they used a different linkage that carried into 2012.
A new mid piston on the Sachs may work. Depends if the issue is the clickers not working due to air in the system, a lack of nitrogen pressure causing cavitation.. OR the old sloppy piston band on the Sachs.
If it's the later than the gold valve will surely improve things!
The symptom is that,I tourn all the clickers from compression on + but the shock still to soft on stroke.
The spring is 5.2 nm and I'm 75kg without gear.
All the time or only when hot? How is the rebound side of things?
Maybe she just needs a good service and a few shims thrown at the comp stack.
quick question, when was the last time the shock was serviced? It is amazing how bad 2 year old (or possibly 9yrs on a 2010!) oil is in a shock
