Ride report 07 sachs
Bikes
ec300 sachs rear
ec 300 Ohlins rear
ec200 Ohlins rear
2 x KTM 525 06
DR350 - that just wont die
we all went for a decent trail ride on sat, But i thought before that ill try out the revalving on the rear shock Hmm much better But still really Hard We checked the race sag from the 5.2 Kg spring - im 85kg with out riding gear - 89 mm Max, 11mm spring compression which in my book meens its to hard for me, But ill ride it and see if it frees up.
Hmm didnt free up riding over small jumps, lets go for a ride anyway Shane and i swapped bikes ( ec300 ohlins ) wow i could not belive it how good the ride was, shane stopped beside me and said i thought you were just bitchin obout the rear end now i beleive you I want My bike Back! - Shane weighs about 90kg so ithought he would be ok on it.
As a side note i Checked the entire linkage system before reassembly and Found NO grease on the O rings But found Plenty of grease in the bearings this had the affect of limiting the action on the linkage it would hang in mid air . I placed a feeler guage between the washer and the linkage and found min .88 mm clearance - I fitted a .84 fibre washer which was nearly the same size as the steel washer.
You can find out what happend to the gearbox in the 2 stroke engine section.
Not Happy JAN
Bikes
ec300 sachs rear
ec 300 Ohlins rear
ec200 Ohlins rear
2 x KTM 525 06
Not Happy JAN
