I have an 05 300, that the clutch drags severely in, as in you cant even feather the clutch. This has happened with the stock clutch ,and the cr250 clutch mod ( i assumed a steel plate had warped, causing the drag. So I did the mod just because). Needless to say, it drags worse with the mod, than the stock clutch. I used the suzuki spacer, and surface ground it to 1.85mm. Also put a dowel rod in the clutch pin, to make sure the master cylinder is lifting the pressure plate as much as possible (ie minimal slop from when the clutch rod begins pushing on the pressure plate). I was using maxima mtl 80w oil, and also used new cr springs on the pressure plate. The clutch basket did not have any grooves, and neither did the clutch hub. I have tooken the clutch apart 3 times now, the last , I checked all of the steels on a surface plate to ensure flatness.
Also, new fluid in the clutch master, and bleed to ensure no air. The lever feels firm with no sponginess.
The only thing i have noticed, is the pressure plate doesn't lift entirely even, but were are talking .01-.02".
How much does the pressure plate lift off of the pack?
