Shifter needed
tzsuzuki
I need a few parts for my 2015 300.
I have bent my shifter a few times (and bent back) I sent my dealer a short list of parts including the shifter. I was told the shifter was back ordered as well as a few other items. If any one has the shift lever (I couldn't find any after market ones) or knows a well stocked dealer let me know.
You can get an Emgo. Any dealer should be able to order it. I just got one for a spare. I believe it was from parts unlimited.
I found some aftermarket one on eBay. It's probably an Emgo. I've never bent so many shifters before I owned a gasser. Weird.
Your not missing much Jakobi, the emgo wears out quickly at the splines and flops around just like the oem one. I had a hammerhead that lasted at least as long as the stock, but it is now worn out as well.
You had a Hammerhead for the GasGas? Do you have a part #?
I recently bent my shifter and bought two for replacements. I got the Emgo and the RFX from Europe for the bling factor. haha. The two shifters are identical except for the coloring. They are even stamped the same, so one must be a rebranded version of the other. I put the RFX on and only have a couple of rides on it, so I can't really say much about the durability. Also, I seem to be easier on shifters than others because mine last 3 or 4 times as long as my husbands.
http://www.ebay.com/itm/RFX-Alloy-g...183077?hash=item5b220b3265:g:rCAAAOSwBnVW8oyX
Mine might have been the RFX as well. It's silver though and looks just like the Emgo. I haven't had any problems with the splines. It could be due to my bad habit of over tightening bolts though. As long as it's kept snug it should last just fine I would think. I check it frequently. I hate loose shifters.
Emgo shifter
I followed the links provided, thanks. The shifters shown made by Emgo are compatible with models up to 2005 according to their literature. And the Gas Gas part number referenced is different.
It sure looks the same? Have you guys with newer bikes used that shifter? The price seems reasonable.
