Shiver 45 less high speed damping?
motopsycho87
I have all my clickers currently at roughly 3/4 open. Could I move to a 5w oil to reduce high speed compression, then close the clickers up to retain the same low speed feel?
Front end just feels a little harsh on hard edges.
Thanks!
Square edges at speed?
You could try a lighter oil which may achieve what you're looking for, as long as you're aware it will also act on the rebound circuit in the same way which may/may not be of benefit.
Yes, that is common with that fork. I had mine revalved at WER and they are awesome. I will look for my paperwork to check the new oil weight recs.
I had to find my WER paperwork. Front forks spectro 85/150 at 110mm oil level. Rear shock 102 to 104mm sag, spectro very light, nitrogen pressure 145psi.
