What is the correct rear shock oil wt? I have a 2005 ec250 with the Ohlins shock. I've looked in the service manual but it only gives the oil wt for the front forks. Also, should the rebound adjuster have clicks? Mine rotates but does not click into positions like the low speed compression adjust or does.
