Hello all, recently there are a few threads here with great info and pics on squish and compression, and port to piston timing (thanks F5 and motopsycho). I have my head off and cut .035" off to get a .045"~.047" squish. I measured compressed volume at 17cc which with a 72mm bore/72mm stroke gives approx. 18.2:1 static compression which sounds crazy high. I would need to cut another 7cc's out of the compression chamber to drop it down to approx. 13.2:1. But, with a 2 stroke that doesn't actually start compressing anything until the piston is above the transfer and exhaust ports, it looks like you should only calculate about half the stroke. How does one accurately measure true running compression ratio on a 2 stroke with all the ports and openings in the cylinder? (I'm probably missing something obvious here). Thanks for any response or info.
