Has anyone used one of these tools?
http://www.yamaha-racingparts.com/model.php?cat=0&sub=0&page=5&product=274
I have not seen one like that.
But recently came across this company that makes cylinder heads for GasGas.
http://www.vhm.nl/?navi=cylinderheadmeasuringtools
Have any of you out there seen or used the brand?
http://www.vhm.nl/?navi=cylinderheads
VHM have been in the industry a long time. I've heard they're a good bolt on for some of the earlier TMs which had poor head designs. For us, I doubt you'd see much of an improvement over a well machined stock head.
Pretty much.. Looks good and still offers some benefits of the interchangable head if you were a serious racer and had varying custom inserts made up. Then again it would be just as easy to have a couple stock heads too.
They do look nice thoughI have a red one and a gold one to choose from. Haha!
I think in roadrace, but still think a bit of solder in a few places is a better tool for seeing what is really going on when torqued up.Think road racing tools. Used to determine piston crown height from top of deck. Zero the indicator on an index plate, clamp to top of cylinder, roll piston through the stroke. The cylinder to head interface is different on those bikes than the GG. No recessed head, IIRC. Once you know your piston height, you can set your squish or volume based on head selection. I raced with folks who had unleaded heads, 50/50 heads, and race heads. You measured the piston, measured atmospheric stuff, got specific gravity of a known fuel, measured the fuel/oil ratio by weight, jetted to perfection, then squeak a piston on the first practice lap.
Then back to the pits, and start over again.
If I ever get my RR bike stable I'll finally get around to skimming my 300 head which I've been meaning to since I bought it. I've measured the squish & compression ratio, I want to close squish up but alter volume to keep compression the same as now so I can kickstart the thing as easily as present which at 5'8" is a serious consideration![]()
