Starter motor
mikethebike1127
Hi there
Been reading that a DRZ400 starter motor fits straight onto a 2004 450FSE. Can anyone confirm that for me.
Cheers in advance
Mike
I does fit however!!!
I can confirm that the Suzuki starter motor does fit however, the positive terminal is on the side of the starter (instead of the end) which fouls the chassis. This is an easy fix....either drill the end cap to suit or use the Gas Gas end cap and rubber grommet. Another issue is the Suzuki unit spins the wrong way!!!. Easy fix....use the Gas Gas brush mounting plate...the brush configuration on it spins the starter the "correct" way.
