How ridable are they in rocks, I mean serious rocks like some parts of NJ, PA, or New England? I fully expect to revalve them like every fork I have ever had, but are they close enough not to hurt me?Springs I might do immediately so I know what I'm dealing with.
Glenn,
I think you might be surprised how good these forks work with the odd set up I'm using. First get the springs correct. This is critical. Then back the clickers out all of the way and turn the pfp valve in one turn. I'm sure that Marzocchi did not intend to for the fork to be used this way but it really is working good for me and Zach, my son. I can not remember my front wheel running down a root in the last two national enduros. I think you guys should give this a try before you spend re-valve money.
Clay
Here is an approximate guide that I worked up on springs:
140 pounds stock front stock rear
160 pounds .44 5.4
180 pounds .46 5.6
200 pounds .48 5.8
220 pounds .50 6.0
240 pounds .52 6.2
260 pounds .54 6.4
The first number is the fork spring, second the shock spring.
Clay
Hi Clay, thanks very much for providing the 2012 suggested spring rate info. I was gonna ask for this but you beat me to it. Surely many folks just getting their new scoots want this info.
If I'm 190 neckid, go with the 200lb rates for fully dressed? (I ride a wide variety from NJ sand/tight to NE rock slogs.)
I'll take the liberty of reposting this in the suspension subforum, and perhaps the Mod will make it a sticky.
Ya know, I was thinking that too, since I run .44/5.4 on my 2006 DE300 (190#, solid B rider), which are fine for everything but Big Sky landings.Looks about one to two rates too high. Expect a 0.44 or 0.46 for a fast 195 pounder on the front, and maybe a 5.4 rear.
