steel gasgas drain plugs
mxdj2003
i just made a batch of steel drain and fill plugs they have 13mm heads and the drain plug is magnitizied they come with new copper sealing washers and free shipping for $20.00 i put them on egay if if anyone is intrested . thanks Dave
Nice. What size is the hex head?
I could be game for a pair of these too.
Do you know if these will fit through the hole
in a Flatland, (I believe), skid plate? Removing the
plate for every oil change would negate the
positive advantage of the hex head.
What is the O.D. of the seating flange?
And if I order them from FleaBay. Should I bid
on the item twice for two sets or just contact you
after placing the bid?
Thanks, Jeff so. Cal.
Just a minor tip to folks buying these....
Be "gentle" when tightening them. Since they are steel and 13mm hex, the weak link will now be your engine case. I don't want to see folks stripping out their cases from over-torquing the plugs.
Please don't take this post the wrong way and not purchase them. I think these are a nice idea. Just be aware that you now have the capacity for more torque on an item that only needs to be snug-tight.
Hey Dave,
Out of curiousity, why 13mm hex vs. a smaller size like 10mm, etc.?
HI Matt , i was gonna go with a 12mm head but i figured 13mm was a populer euro bike size so thats what i went with, a few people have told me about possible overtighting issues with the steel bolt , which i can understand but every japanese make has steel drain plugs.
local buyer
Hello I live Spartanburg, Would like to purchace a set of your plugs for my 05 300. Can you please call my cell number and I'll come by and pick them up. 864 357 8794 cell.
Thanks Ken
i'm glad you like them, i made another batch this weekend so if any one is intrested hit me up
Please make some hex headed front axle bolts. (same size as the spark plug wrench)
It's tough carrying around that big allen head wrench.:D
i could make an insert that goes into the hex in the axle and has a 13/16 head on the outside ,i could make the tool about an 1'' long so it will fit in your fanny pack nicely.
Good idea.
How about making a hex headed insert that you press into the allan head and leave it installed on the bolt.
