rgranger
cable is new, throttle tube is free. can ride it all day in the flat bits and breaking bumps and not have an issue. Get into some serious whoops or this washed out area that I test on and it will hang wide open until you kill the motor and restart. it is almost like it is some sort of vacuum thing? I was wondering if the slide could be bouncing about, but that seems pretty far out there (and I have the strong return spring in).
This was supposed to be a weekend to shake out the suspension rebuild that Brent helped me with, turned out to be slightly less fun and a lot more scary.
Do the slides wear at 40 hrs? Bent needle?
