Its a crank with a longer than "normal" stroke.WHat is a stroker crank? Tried google but not sure it is giving me the right answers
Well the easy way is to find a rod with a bigger pin so you can offsetbore the crank for more throw.
Why would you bother?
The right needle and a head reshape will bring you more performance
does that not increase the compression?Its a crank with a longer than "normal" stroke.
This is a trick mostly used in forstrokes to increase the capacity, like boring out the cylinder. Whether you select to bore or to stroke (or both) would depend on how you want your engine to perform.does that not increase the compression?
What are the benefits of this mod over just ensuring proper squish or modifying the head (insert) to increase the compression?
Does anyone sell a drop in stroker crank? if not, who is a recommended builder to do the work?
Thank you,
John
I have looked at the big bore option, but I am installing a gasgas into a trx250r (Roll Design) chassis and am looking for added torque, and a stroker, in my opinion is the best way to go.
from my research, eric gorr, is probably who i need to speak with,
thoughts?
