Studded Tires?
sam
What studded tires are available now that you can not purchase Trelleborgs here in the States?
Sam
Trelleborgs were bought out by Mitas. They are using the trelleborg molds and making the same tire called Mitas Sport Winter Friction. T434 is the front, T454 is the rear. I just put a set on my bike.
check out these; gripstuds.com, I've been using them for a couple years now. I really like them. If your tire gets worn out you just screw them out and put them in a new one. We run in alot of rocks so I use the short ones. If we were in a little better country with less rocks I think I would reccommend the longer ones.
These are very good, I use them (they're called Bestgrip the ones I use and look the same) very easy to put in, I use an electric screwdriver, and they seem to be indestructible.
I use steel 15mm car studs. A stud gun and a drill to pre drill the knobs. It takes a while, but it works.
