GasGasDreamer
It takes a while but you soak it with wd40 and heat with a torch.
this draws the wd in. do this for a a couple days. hammer with block back and forth, one side to the other. if this doesnt do it then then press it out but again on both isdes back and forth.
in my day i was a surgeon with an torch. i could cut lifters out of engines with out harming the bore. i dont thnk thats possible here bc its too long.
can you use a hacksaw blade and split/slice it?
