What's the consensus, take the steed back to the dealer or do it yourself?
Depends what's easiest for you, and your relationship with the dealer.
I need to check my VIN. Does anyone know if the crank nut has changed over the years? Namely the thread pitch? I have a spare one from around 2013 that I ordered.
Jakobi, dealer told me that the nut is the same for the 2013.
Why didn't we see any failures on other models if they have been using the same nuts I wonder??
Crossed wires, the dealer told me that the 2103 nut that you bought is the same as the one that needs to be installed on the current bikes.
It should have the groove cut into the corners.
Easy to check by looking through the oil level window.
Lol. I dont think the VIN or the lhs crank bolt are visible through the sight glass..
