GasGas EC 125 2006
In the attached video, especially later in the video, thers a loud ticking noise. I am 90% sure it is coming from the engine.
I am also quite sure it is the clutch basket that is worn out and has play, causing the noise. As it is maknig noise, I assume it is wayyyy to worn out and needs to be replaced.
I am still making this post to get more opinions whether its the clutch or not, and what to do.
Do mind that almost everything in the engine was replaced, EXCEPT the clutch and the clutch bearings. This means that theres always the possibilty that the 2 roller bearings inside the clutch might be worn out, and maybe it isnt the clutch.
Anyway, heres the video of the ticking noise:
https://streamable.com/6bx66j
Also, In the following link, you can see a video showing the play in the clutch. This was during engine reassembly. I made a thread about this a month ago or so whether this is bad or not, but unfortunately didnt get an answer.
https://streamable.com/z2i60t
Lastly, a picture of how it currently looks
