I noticed my rear sprocket has a bit of a wear pattern to it. The chain and front sprocket are original. The rear sprocket is an aluminum 50T that was put on shortly after purchasing.
It is a 2005 EC 250. We ride some technical stuff out here which is the main reason the former owner put on the 50T.
After having ridden it for several months, I'd like to consider a 51T or 52T to make second gear a little more useful in some semi-tight trails. Is the 51T a big enough difference for my application? Will 52T be too much? Will I find myself spinning the tire too much with a larger rear sprocket?
What are good bang-for-the-buck chains (O-ring) and sprockets?
Thanks,
Rick
Thanks,
Rick
