Tools/parts to service bottom end
stay_upright
What 'special' tools do I need to split the cases and service the bottom end of the engine.
I've done a KTM200 before and think I got away with holding the wheel on the brake to undo the nuts I needed. Now I have spare clutch plates so I could make up a tool (long bar bolted to clutch plates) to hold the clutch basket. Is that everything I need?
What gaskets do I need ( will pre-order them) and what would you replace as matter of course while the cases are apart - I don't want to replace every bearing if I don't have to (or would that be a better idea?)
Should I invest in an airgun, will that help a lot?
Any other tips including what to undo/strip while the bike is still in the frame would be welcome.
I may even write a guide if I'm feeling nice since I can't find one already.
What 'special' tools do I need to split the cases and service the bottom end of the engine. fly wheel puller, case splitter. theres a case bolt behind the fly i think so might as well get them to do the both or buy the 2. I just gave it to a shop and asked them to do those 2 things.
What gaskets do I need ( will pre-order them) and what would you replace as matter of course while the cases are apart - I don't want to replace every bearing if I don't have to (or would that be a better idea?) I'm not a fan of punching myself in the nuts, but if that's what you're into go right ahead.
Should I invest in an airgun, will that help a lot? Yes.
Any other tips including what to undo/strip while the bike is still in the frame would be welcome. Clutch and crank nuts.
good luck.
