If it was running well, be sure to measure the base gasket (s) and replace with the same. If you want sharper performance pull the head but leave the jug on. Check your piston to exhaust port height (see F5 or Jakobi thread) and then decide on base gaskets. Check/set squish based on your new (or carryover) cylinder height.
PlusOnePerformance
