Top end rebuild, lots of orings?
Thompo
Hi folks,
Finishing off a top end on my mates 03 300.
In the gasket kit i have
base gaskets, powervalve cover gaskets, reed gaskets, exhaust Orings and gasket, water pump gaskets and head o rings.
There is also 7 other Orings.
Where do they go? I didn't remove any this size.
See pic attached
Cheers
Looks a bit like a full gasket set..
2 x o-rings behind the counter shaft seal.
1 x o-ring on crank, clutch side.
Sometimes these kits are a bit generic and will throw in a few bits to cover variances across a couple years of a similar engine.
Two of those medium orings look like the two I just replaced with my countershaft seal and bushing.
Yeah what a screw up that is. Never seen a groove that needed 2 Owings pushing on each other.
