Top shock bush crossover?
swazi_matt
Active member
Anyone know if the top shock bush (spherical bearing/heim joint/rose joint) on the top of the Sachs shock crosses over to a more common brand bike?
Anyone??
The guy I asked to get one from the bearing shop seems to have lost the slightly worn one (bearing shop could not source one either) and gas gas doesn't have any in stock
Since the movement is in one plane I don't really understand why they use a spherical bearing. Could I replace it with a standard ball bearing that is the same width?
Anyone??
Have any pictures? I am going to take my own shock (sachs) out for either replacing or service it, but I thought it had much side to side play.
Take some pictures, ill take mine out and measure the bushings so that you can machine one out.
/S
I have a spherical bearing out of the bike at the moment, its for a ohlins rather than sachs but I guess its the same? i'll take a look tonight and let you know what ref numbers are on it
All balls have them in needle bearings. Not ideal but..
For the top of the shock?
I have been considering using a normal ball bearing to replace the spherical bearing as I believe the GG engineers decision to use a spherical bearing is more from longevity than a need to rotate in multiple planes. I will see what I can find and use while I wait for GG to get new stock
Pictures not working but the link I sent is a spherical bearing which includes the part number and dimensions to compared against your bike.
I see that now link wasn't working for me earlier. Thanks
Could not get it from any of the bearing suppliers here, but did manage to find the old one so just greased it up and put it back in. Can hardly feel the play as part of it was from the bottom bearing that I also replaced.
