evanchochrek
Hopefully someone can explain to me how the chain adjuster bolts on a gasgas work. they do not thread into the swing arm like other manufacturers so 2 laps into the race I swapped the rear end pretty hard and less than a mile after that, I tossed the chain. After i got the chain back on, I noticed the slack inthe chain was way too much. It had about 4-5 inches of slack! Then I noticed the sprocket side of the axle was all the way pushed forward and the disc side was still where it was supposed to be. the odd part was the axle nut was still tight. I am positive everything was good to go for the race and nothing was left UN-tightened. After coming from a dead last start in the a-vet class to 4th in one lap, i was dissapointed, but now that I'm over that, I just want to make sure it doesn't happen again. whats the deal with the chain adjusters how they work and why is there rubber grommets on the bottom of the swing arm just below. Is it just the pressure of the axle going forward that keeps them in place? should I put some thread lock on the adjuster nut, so it doesn't move? I think that is the only reason that my axle moved. the adjuster must have rattled loose all the way forward, then when I swapped out that must have been enough force to tweak the rear end. any info for a newbie on a gasgas?
