blitz11
After 6 months of work on nights and weekends, I finally have a CDI with which i am happy.
I had it done last week, but I blew up an ignition coil. I was testing at 11,000 rpm, where i am able to deliver 350 volts to the coil (the stock delivers ~200 at that speed). After about 10 minutes, the coil blew up. Too much voltage/energy.
So, a new change, and I now limiting voltage to 300 volts. I've been running at 11,000 RPM for an hour and the system is rock solid.
The ignition is in a breadboard stage now. After I help an 8'th grader with his go-kart project (I'm his mentor), I am going to solder up a proto board, and get that running.
I am thinking of writing a semi soup-to-nuts theory of operation on ignition systems, from the rotor, stator, pulsar pick up, and CDI fundamentals. I am also going to have some circuit boards made; 3 for my bikes, and two (or more) for members here who are willing to test. GMP and Kenndunn have expressed interest in the project; I'd be willing to send them each a test CDI if they're game. I'd ask them to test it on their bikes so I can gather some durability information. (It runs cool on the bench even at 11,000 RPM, but it's not yet been in a bike.)
The ignition is fully programmable. I need to build a library to simplify the process of building your own advance curve. That will greatly simplify that process.
Once I have the protoboards done, I need to specify connectors for the USB (for programming), for the map switch, and for the connection to the bike. This will take me a week to specify the connectors, and find a suitable switch for the map, and an enclosure.
When I started this, i thought i'd just replicate designs which are on the web. To be honest, NONE of them work in this application. However, as I worked through this, i hit on a design i'm really proud of. Looking at what Vortex gets for their programmable ignitions, I am actually thinking of starting a business to build and sell these things. Might as well get something out of my work. I know that this performs better than the CDI that came on my bike; programmable, much higher spark energy/voltage, and multi-map.
(I already have a job, so I am looking for something to do for fun into the winters. My day job is described here: www.bus2.me.umn.edu .)
Anyway, if people want a full theory of ignitions, I'll start writing one as I document my work. I won't go into my final circuit design as I have not seen anything like this, and I think it offers me a competitive edge on what else is out there. I'll look for some feedback here.
I also promised LEDs for diagnostics on this. I have changed my mind. What I'll offer is a small diagnostic box with LEDs which you can connect to the stator wires, and it will tell you whether your alternator is putting out sufficient juice, and whether your pulsar is working well. This is a much cleaner approach.
This would work on all bikes. Might be handy, knowing what I know now.
Basically, if you have good signals, your CDI is toast. I blew up a few of mine working this out.
I have a few photos and a video of the ignition winding down from 11,000 RPM (it shows the advance go from 0 degrees at 11,000, up to 30 degrees at 3000 RPM, and back to zero at ~2000 RPM. (The 30 degree number is exaggerated for demonstrative purposes).
I'll post those once i figure it out. (If anyone has picture/.avi file ideas, I am all ears.) I am not sure of the best way to do that. If people want at theory of options, please let me know. (IT might be a couple of weeks until i finish that.)
Thanks for reading.
blitz
Thanks for reading.
blitz
