what 2 stroke oil to use?
kiss161
well got that 200 ec the other day and was wondering what type oil guys on here run in there gas gas. have used klotz in many of my bikes just wondering what most use thx...:cool::cool:
also what type crankcase oil should i use weight, brand ,and amount for the gas gas 200 ec
Any modern high flashpoint synthetic 2stroke racing oil is good. Amsoil, Motul, Maxima, Castrol etc. Klotz should be fine as well. Stay away from any castor blends, they burn dirty.
thx ..also what type crankcase oil should i use weight, brand ,and amount for the gas gas 200 ec
owners manual calls for 1000cc 10w30??????? just over a quart?
Crankcase? Gearbox?
My 2010 EC300 takes 900ml of 10w40. Gas Gas advises the use of GRO (global racing oil) both for the 2 stroke fuel and for the gearbox. Obviously different oils for each.
Most people run their fav 4 stroke oil for the gearbox 0w-30/0w40. As long as it doesn't contain friction modifiers that will mess the clutch plates up then no issues.
I personally use Amsoil Dominator at 50:1 for the fuel and Amsoil 10w40 in the gearbox.
Crankcase? Gearbox?
i meant gearbox/trans sorry :)
Premix : Anything fully synthetic in a brand you have heard of that you dont mind paying for.
Gearbox : I use a litre(because we are metric in NZ) of whatever I get cheap, which at the moment is elf 4hp eco semi synthetic, and ELF 2XT for premix.
Hi Noobi,
Where do you get ELF products from in NZ and what are you paying for the
2T ? I currently use Castrol TTS but the price keeps going up:mad:
Thanks - Harry
My preferences go for ester based synthetic oils. I run Motul 800 factory line Off Road for the gas (3%) and Motul 5100 for the gearbox.
If I can't find Motul I go for Fuchs-Silkolene
is this elf close to klotz?
Anything will be fine. Stay away from castor based oils. I like Klotz R50 because it smells good. So if you are going to ride in front of me, can I put in my request?
I run amsoil dominator as did the previous owners of my bike, the inside of my motor was very clean when torn down with an oily coating on the powervalve and its bearings that wiped right off :). Its also very easy to get around here I buy a gallon jug at a time from the local car parts place they're a amsoil dealer a local bike dealer sells it too.
IMO any named brand premix oil that wont gum up your powervalve will be fine.
I run synthetic amsoil or rotella in my trans 0 40, 5 40 or 10 40 it works good and is easy for me to get.
