wheel spacers
kpuc11
hello I am new to gasgas, I was wondering where is the best place to get wheel spacers? also what are the longest lasting wheel spacers??
OEM should be fine.
Check out GoFasters (site sponsor). They have a hardened left side they sell. The right side is on backorder right now.
I had the checkpoint ones and just recently switched to the SKF wheel seal kit. checkpoint lasted longer than oem with regards to grooving, the SKF i have not had for long, but the fact that the seal turns with rather than against the spacer means the spacer will last longer - still to see if the seal lasts
http://www.skf.com/us/knowledge-centre/media-library/index.html#tcm:12-125118
http://motocrossactionmag.com/news/mxa-team-tested-skf-wheel-seal-kits
What SKF part # did you use Matt?
-SKF spacers are meant to go down with their bearings.
That's why they come together (and cost double :( )
the groves were insane (and so was the bearing that came out in pieces)
-Checkpoint spacers last much longer than stock.
beware : SKF rear spacer has larger outside diameter than the stock/checkpoint ones.
It will not fit stock/allballs seals! :eek:
make sure you have a checkpointer handy if you have another brand for spares in a race. ;)
