I measured all my shims. MX-Tech sells all of them except:
6mm x 10mm x .2mm
6mm x 11mm x .15mm
8mm x 24mm x .4mm
I guess I'll just throw the old ones back in ?
Do these stacks sound OEM ? I assume the "rebound" is since I had to file the lock off. The previous owner said he had changed the valving ? Any advice/recommendations before I order shims ? I was content before I got into this, except for a leaking seal, but would make a change if advised by you pros.
Rebound:
14 x .1 x 6
16 x .1 x 6
18 x .1 x 6
20 x .1 x 6
12 x .15 x 6
24 x .1 x 6 delta
24 x .1 x 6 delta
Check: (4x) 24 x .1 x 8 i.d.
Compression:
Check: 24 x .4 x 8 i.d.
10 x .2 x 6
24 x .1 x 6
11 x .15 x 6
20 x .1 x 6
18 x .1 x 6
16 x .1 x 6
14 x .1 x 6
10 x .2 x 6
11 x .15 x 6
6mm x 10mm x .2mm
6mm x 11mm x .15mm
8mm x 24mm x .4mm
Rebound:
14 x .1 x 6
16 x .1 x 6
18 x .1 x 6
20 x .1 x 6
12 x .15 x 6
24 x .1 x 6 delta
24 x .1 x 6 delta
Compression:
10 x .2 x 6
24 x .1 x 6
11 x .15 x 6
20 x .1 x 6
18 x .1 x 6
16 x .1 x 6
14 x .1 x 6
10 x .2 x 6
11 x .15 x 6
