WTB Cases for 2001/2002 EC250/300
Sierra Gasser
Hi Guys I am looking for a set of cases for a 2001/2002 EC250/300 the 99/2000 takes wrong RH main bearing .The 2003-2004 cases have the larger swingarm bolt hole so I would have to drill the frame holes & rear engine/linkage brackets larger & hope they line up .
01/02 cases
Hi Wheelie Man, Thanks for responding .The 01/02 had the 14mm swing arm pivot bolt .The 03 & up is a 17mm so if yours have the 14mm (approx) pivot hole then the next issue is the main bearing size . The 01/02 have a 68mm OD bearing on the right side and a 62mm OD bearing on the left side . The cases I had laying around are for a 99/2000 and both mains are 72mm OD on those years so I cant use them unless I switch to a 99/2000 crank . Thanks again Keep On Gassin ! Mr GasGas
