WTB Front Wheel and Rotor for 2003 EC250
reiterrider
Looking for a front wheel that will fit my 2003 EC 250.
Preferably with decent bearings and appropriate spacers.
I'm going to mount a trials tire up front for some dual sporting.
I've got a '07 front wheel in good shape with rotor and magnet for $175.
Check and see if it will fit or send me some dimensions and I'll check it.
If you need a photo, send me your email.
Thanks,
Thanks,
the 07 front has the bigger axle...won't fit the 03
The rims should swap just fine. You will just have to use the appropriate spacers and bearings.
I have a wheel and rotor off my 99 ec200 that will fit right on your bike. Bearings, rotor, and rim are in very good shape. Rim is an Excel and has some small scratches but is straight with no dents and all spokes are tight. $175
I forgot to mention that this wheel is heavier than the wheel on my 07 gasser. That's because the rim is heavier and much, much stronger than the light DID Dirt Stars that come on the newer bikes. The Excel rims are comparable to the U shaped dirt stars that came on my 01 gasser.
