WTB-WP 43 triples and 5.4 Ohlins shock spring
rpduc
Anyone have either of these available?
Lower triple with or without stem or complete triple for WP 43s
Can't tell ya what the actual Ohlins shock model # is but as far as I know the same spring fits all of the pre 2006 Ohlins equipped units. I know for sure '03, '04, and '05 cuz I've interchanged them. IIRC they went to Sachs in '07.
I have the 5.6 spring that came on it ('05 MC 250) and I'm currently running a 5.2 that I took off an '03. At 190 lbs. w/o gear I think a 5.4 would work better...
The numbers on the 5.6 spring I have read - 00596-12/56 L344
Last time I went thru this no one on here really knew exactly what those numbers meant. One would think that L344 relates to length but this spring measures 271.5 mm.
no triple tree bottom, 2 wp 43mm tops. sorry.
i was wrong about the spring. i have a 5.4 spring i traded for, worked fine on my 2000 ohlins. it's black, came from a sachs maybe? - i got it from widebear ages ago.. i know it fit mine. i can pm you dimensions etc. i'd trade it for that 5.6 you have.. the 5.6 is what i need for my 1984 it200 :)
l344 is the build date. i believe 34th week of 04.
ps 5.4 is what i ran, 185 without gear, it's what lt suggested...
Sure, I'll trade for the 5.6 long as it's the same length, dia. etc.
As stated above the length is 271.5 mm (10-11/16") and the I.D. Is 58mm (2-9/32")
PM me or e-mail me an address and I'll do the same.
