Quick intro -- this is my first gasser and first real dirtbike (06 EC250). Previously I have had quite a number of 2Ts, but all were on the street. I bought a DR650 and took to the trails... you know how that ended up. Now I have a gasgas.
I took it for a spin when I was looking at it, and it ran great. Like a scalded cat. The only thing was that it idled a bit high (done lots of searches on that), about 2200rpm. Idle screw seemed to do nothing. Choke made the engine race.
I took the carba apart suspecting a clogged pilot circuit, nothing. Cleaned it all anyway and reassembled. Still had a high idle. I noticed that it would drop to a reasonable level with a combination of blipping and airscrew work, best was one turn out, but it would not "stick". If I blipped the throttle, back would come the high idle. !?! stuck throttle cable! I turn the bars and the bike races... ok done. I took the cable off off the handle, and rerouted the cable making sure all was loosey goosey, lubed it too. Nice and smooth. All done I thought...
NOW the thing will not even idle, high or not. I have to keep blipping it to keep it running. Nothing I do with the air screw or idle screw will make it tick over.
I did notice that when I took the bar assembly apart that I heard the slide "thud" down, when I removed the white pully.
Since I have been out to the garage I have been thinking... Does the cable adjuster at the bar need to lift the slide slightly to make it run? Is that not what the idle screw is for??? lol
Any suggestions would be greatly appreciated. Sorry for the long post.
