http://i1258.photobucket.com/albums...DAB247F-5118-000002BC388D3A0E_zpsb30c3a41.mp4
Re-greased the swingarm and linkage bearings 40k's (1 ride) ago. When I put it back together everything was super smooth, no binding at all. Torqued everything up as per the torque table on this site (which is the same values as the '11 GG user manual). I'm 90% sure everything was normal on the ride I just went on, although I did notice the rear felt harsher and kicked more over square edges and decent sized logs.
Bought it home, washed it, put it on the stand to play with forks. Took it off the stand, it's making horrible noises as per above video.
Sag figures are normal, although if I let the bike sag under its own weight without pumping it up and down it only sags 5-10mm. So something isn't right.
Any opinions?
Any opinions?
