Merry Chrismas everyone.
I just put new seals in my forks and found the comp adjuster assembly at the bottom of the fork loose. I consulted the WP assembly manual and attempted to tighten it first with a ratchet which didn't work. So then I tried an impact driver(not the smack-it-with-a-hammer kind). I held the damper rod at an angle to hold the inner part but it wouldn't snug up. It just kept spinning. Using the impact, I broke it at the land where it seats on the copper sealing washer. What can I do now? I took it out and I can see that it wont do it's job with that little lip broken off. Any suggestions for where to get a replacement? used? or cheap Thanks
