07 timing?
wence
Bronze Level Site Supporter
Hey Guys,
Just rode a six hour day / night ride and I am still having the bike ping at wot and bog down going from 1/4 throttle to wot, unless I feed it gradually.
Talking to a mate, he says that it sounds like a timing problem.
I had a previous thread about timing but didn't ask what the actual timing before Tdc should be.
Does anyone know what this is ?
The bike is an 07 Ec300 and I assume it is an Australian version as I am in Oz(not sure if they are different).
I am running castrol tts oil at 32:1 with 98 octane unleaded.
My jetting is 180 main,42 pilot ,1.5 turns on idle screw, N1eg plug, 2nd clip from top.
Any ideas or help would be great as I am scared to ride this normally for fear of seizure etc.
Thanks in advance ,
Mark.
I doubt its a timing problem.Spec is 1mm btdc I run at 1.5 for a little cleaner off idle perf. Why are you running such a rich gas-oil mix? Thats going to create a leaner a/f ratio and as a added bonus lots more carbon buildup with potencial glowing hotspots, that combined with high coolent temp's, perfect environment for pre ign.
Thanks widebear, I will change the timing first as the mtor was rebult b4I purchased and the timing may be wrong.I think I wil adjust it to what you have.
I am going to change the a/f ratio to 40:1 and will also check and changejetting to rid the bogging.
I'll ave a go at this on the weekend (I hope), and let you know how I go.
Cheers Mark.
Cheers Mark.
Hi mark
GG recommend 50:1. Go with it. GG would hardly recommend a 50:1 ratio if the engine was going to be borderline lubricated would they ?
I have run 50:1 in my GGs for years and never had a problem. Use the best fully synthetic 2 stroke oil you can get and you will be fine. 32:1 is way too oily and too lean fuel wise.
Will do , I'll let you know the outcome.
I think the onlyt half decent oil we have is motul, can anyone suggest another good oil?
Cheers Mark
Cheers mate, will purchase later in the week once I am paid. Just as a matter of interest what do you guys pay for the above?
Thanks again,
Mark
I use Rock Oil Syn 2 race and I sell it for €14.50 euros for a litre of it.
Not sure if you can it in Australia.
Mark,
As you live in Adelaide give Show & Go a visit they are the experts on Keihin carbies,they sell shudco needles, review all the post on carby jettings within this forum I would suggest a CCK or CEK needle. They would also sell many good Fully synthetic oils- Belray, Motul, silkolene, motorex: 40:1 is a good safe ratio
Noel
Bike is now running 50:1 Motul.
180 MJ, 42Pilot,Middle clip.
Feels very nice throughout the range, no bogging.
By the way when I removed the main in the first instance it had a little bit of crap stuck in it.....This definitely wouldn't help.
Anyway all good now, I will be testing it in the next 6 hr road trial this weekend, fingers crossed , all should be ok.
Cheers Mark
Bike goes very well now and has passed its first six hour since changing the jetting.
Thanks to everyone that helped out.
Cheers Mark
Cheers Mark
What needle did you settle on Wence?
I ended up just using the standard needle and could get it pretty right.
I tried a 200 main and it was obviously rich, then a 175 and it felt awesome ( no pinging), BUT TO BE ON THE SAFE SIDE I REPLACED THE 175 WITH A 180 MAIN,The standard needle is on the middle clip and I think I have a 42 pilot, 1- 1.175 turns out.
Like I said it did run a lot better with the 175 but I would rather the reliability.
Since then I have gone to approx 40-45:1 .
Still cool.
All the best mate,
Mark
07 timing
I have done plenty of timing belts on other cars. just never a subaru. and it just freaks me out. Its just sooo damn long
