E Elliker New member Jan 22, 2009 #1 can somebody tell me the correct amount of 2 stroke you need to mix with the petrol? say with 5 litres of petrol
B Brian VT Member Jan 22, 2009 #2 Elliker said: can somebody tell me the correct amount of 2 stroke you need to mix with the petrol? say with 5 litres of petrol Click to expand... Usually between 50:1 and 35:1, depending on the oil, except for trials bikes. So, 100-140 ml oil to 5 litres petrol.
ramcclure200 Gold Level Site Supporter Jan 22, 2009 #4 Check this out http://www.csgnetwork.com/oilfuelcalc.html it should help you out. Ron 2004 ECDE200
Dingo New member Jan 22, 2009 #5 I use Maxima Castor 927 @ 40:1. Good 0il and it SMELLS AWESOME! Like the old methanol bikes from the 80's! http://www.maximausa.com/products/2stroke/castor927.asp
MattR Super Moderator Jan 22, 2009 #6 Premix tables located on our site Premix Tables for common ratios: http://www.gasgasrider.org/forum/showthread.php?t=182
