Jakobi
So today I went at it.. Sorry I didnt bring the camera along. I'll take the bike out tomorrow with the cam running as a demo.
I tried needles and pilots and more and more.
N1EG#2, then #1. Too rich off the bottom. Pulling over and having to use a smaller pilot to compensate. Racing idle when leaned out enough.
N3CH
#3 Wouldn't rev past 1/4 throttle smoothly. Blubber blubber.
#2 As described. Vibey and slow to rev but sounding clean
#1 Wild.. but too lean to run safely.
N3EJ (with pilots 38, 40, 42)
#2 Wouldn't pull clean past 1/4 throttle.
#1 38P high idle after opening the throttle. Lean pilot.
#1 40P dialed in. Quite smokey when cold. Pulls so cleanly. Idles well
#1 42P runs well when dialed. Very very smokey. Big smoke on decel even at full temp. Will also idle but a bit on the fat side.
All on #1 absolutely crisp from 1/8th - 3/4th. Felt to sign off/too lean on the top.
End result some 8 hours later after much tinkering, head scratching and trying things multiple times.
40 N3EJ#1 178. Weaponary! wicking it up off idle in the tight stuff almost put me into a tree once or twice.. When on band its in a world of its own.. Today has been well well worth it!
N3CH
