sneaky98gt
Hello all.
I recently acquired a very nice 2011 EC250. I rode it for a solid 4 hours this weekend in the terrain I typically ride (hilly, rocky, very technical enduro type). All in all, I am beyond pleased with how much of an improvement this bike is over my previous bike (CRF230F).
However, I've got an issue with jetting that I'd like some help with. First, a few facts.
Bike is stock except an RB Designs head mod and carb mod. I don't know the exact "model" of the carb, nor the extent of the mods performed, but it definitely has the divider plate and is bored out to 39 mm. Pictures below. 178 main, 42 pilot, CEK needle on 3rd clip, #7 slide, and the adjustment screw (not sure if it's fuel or air) was only 1/2 a turn from all the way in (I haven't adjusted anything, just ridden it as is). Supposedly, the carb is exactly as it was when returned from RB.
The previous owner put in a new BR8ES plug before I bought it, and when I test rode it, and rode it around the farm just a bit at Christmas, I was absolutely blown away at how much off-pipe torque it made. This is my first 2 stroke, and I've always been partial to the power delivery of a 4 stroke, but this bike has blown my world open. And the power it makes on the pipe is equally ridiculous.
So, back to the "real" riding I did this past weekend. Elevation was 1500'-2500', roughly 30-40 degrees F over the day. The bike started off strong, but as the day drew on, I could swear that it was losing some of that low end torque. It was still pretty good, and would easily lug WAY down low, and made plenty of power up top. But it didn't seem to have that blow-my-mind low end that I remembered when I first bought it. Being that we're mostly riding enduro-type stuff, the bike wasn't being wound out on the pipe 24/7, but we've got quite a few big hill climbs, so it certainly wasn't just lugged around all day either.
One other tid-bit to know: I don't know which is "rain" and "sunshine" because I don't see any logos on my switch, but on the larger button (which I assume to be the sunshine), it runs great. But on the smaller button, it starts breaking up in the higher rpm. Not sure if that has anything to do with anything, but it definitely doesn't seem right.
When we got back to the truck at the end of the day, one of my friends suggested that it was rich based on the spooge out of the tail pipe. I know that's not always a good indicator of the jetting, but between that, the amount dripping out of the powervalve drain, and the fact it's mixed only 50:1 with a very low flashpoint oil (Maxima Bio 2T), it's probably a little rich. Pulled the plug, and at least to me, it also shows it a good bit rich. Pictures of both the tailpipe and spark plug below.
Being a little rich on the pilot wouldn't surprise me, because even after sitting all night at ~15 degrees F, and it only being about 25 F in the morning, it fired right up on the choke on the first kick, and idled perfectly with the choke immediately turned off.
I had a spare plug, and swapped it in, and took it for a quick rip before loading up for the day. The difference was massive. The low end torque was completely back, and the bike was as awesome as I remember it being. The new plug completely fixed it, though I'm not sure for how long.
So I guess I've got 2 questions.
1. What are your thoughts on the jetting? Should I go a little smaller on the pilot? Different needle?
2. Is this a typical thing, for the torque to go away some as the plug gets gunked up, and a new plug restores this? I'd always been under the impression that plug was either fouled and wouldn't run at all, or it was fine. I didn't think there was an in-between.
Thanks in advance for the help!
