twowheels
One more time, just for fun (and because service manual writers seem to have overlooked the obvious) ...
What is the torque spec for the cam caps?
What is the correct position of the intake cam when timing? (I'm supposing piston at TDC, mark 3 pointing to 12 o'clock, mark 2 level with head)
What is the correct position of the exhaust cam when timing? (I'm supposing piston at TDC, mark 2 pointing to 12 o'clock, marks 1 and 3 level with head)
Is there a timing mark that indicates TDC on the ignition rotor (I didn't see one) or on the primary side, or are you just using a gauge to show TDC?
Many thanks ...
Many thanks ...
