bergerhag
I am only good at basic maintenance on my bike so it looks like I will have to take it to the dealer as the problem is getting worst. Forgive my ignorance but what does the "technoresearch VSTDS software" do? and if I left those wires plugged in, the bike would not run as strong correct?
thanks
The Techoresearch software is a diagnostic tool for fuel injected bikes. It can show readouts of injection sensors, list fault codes and show some other gauges, like rpm. It can also perform tests of various components aswell as adjust overall fuel trim.
http://www.technoresearch.com/Products/VDSTS-Motorbike/VDSTS_Motorbike_Features.htm
There are some screenshots too.
Bike would not run as strong with cable connected, but if you have an overly rich mix(due to whatever problem) then connecting them would make the bike start and run better. That would then indicate that the bike really has a problem in the fuel mix area. With the VDSTS software you can verify the functionality of all your sensors.
Don't know if this has been up before, but have you checked that the restrictor plate is removed from in front of air filter?
Oh, I had another problem with my '05 this monday, after 8 hours of hard riding in the weekend. The bike just wouldn't fire. Starter turned very good. Spark turned out to be weak and irratic. Problem was a burned out high voltage winding of the spark plug/ignition coll assembly.
