fastisbetter
I recently purchased a new 07 fsr450. Very pleased with it until yesterday. I was out on the trails with it and it started to run rich and load up with gas, was smoking black like crazy, wouldn't idle and would only go if I really was giving 'er. Then it seemed to lean out and would only idle, if I tried to give it gas it would stall no matter how I tried to feather it. Pushed it out of the trail to the road, loaded on a truck and took it home. Now it won't start at all. I pulled the plug and it was dry but black so I cleaned it and still no go. 4 weeks ago when I bought the bike I took all the electrical connections apart and put dilectric grease in all of them because I heard that they can corrode leading to these type of symptoms but since I already did this I am assuming it is not this. I will be picking up a new spark plug today but failing that, I am stumped. This bike has less than 1000kms and is fuel injected so I thought I was done of this running rich/lean confusion that a carb brings. Any body that has had this problem please let me know what you came up with. The bike is still warrantied but the dealer is 3hrs away so, without a truck, I would like to be able to fix it myself. Many thanks in advance
