Last year I brought a 98 E250 in parts. I've never seen it run but I knew the previous owner and it was fine until he took it all to bits. I've completely rebuilt the engine. New bearings, seals, piston etc. I finally got it all back together but I cannot get it to start, well not 100% true but here goes. I've filled all the fluids and filled up the carb with premix through a remote tank (pop bottle). Changed the plug and I definately have a spark. Choke has been tried on and off but it won't even back fire/pop/bang/anything. It will run for a couple of seconds if I spray carb cleaner into the carb. I've cleaned the carb twice, it's a real simple design and I cannot see any blockage. Air screw is 1 3/4 turns out. Reed were replaced when I rebuilt the bike. I've tried disconnecting the air box but still no luck. I've tried kicking it with WOT and fully closed throttle, and everything inbetween.
Does the fact that it will run on carb cleaner mean that the piston timing, reed valves and everything else after the carb is working ok? Am I missing something obvious?
Any advice is really appreciated, I've worked out that about 200 kicks is my limit for a days exercise!
