adv rider
Well I have been working on my bike, in an attempt to ready it for it's first ride. So I have been slowly disassembling so I will know my bike- which is 11' 250 race. Here's a few ?'s, remarks
1 - How is everyone getting the wiring out from airbox to remove subframe? The large plug for the ignition box doesn't fit thru wiring hole
2 - How is the quality of the original chain? And what with no master link, I have only seen that on street bikes. And has anyone installed a clip type master link, and what brand? Their is no brand marking on chain
3 - It looks like I need to pull the swing arm to remove linkage for service- True? Also looks like I can't remove lower shock bolt without removing linkage.
4 - I never seen that type of plastic bell on the carburetor, At first I thought the airbox boot hose clamp was in the wrong position..but once I pulled the subframe back I saw that plastic bell I realized the clamp was in correct spot. Is that bell permanently on there? Has anyone ever had one loosen up and allow unfiltered air{dirt}into engine?
5 - float height was at 7mm, 40/180, going to reset float, leave the 40, and try 178. I have a NECW needle coming
6 - has anyone put a # plate in front? from what model, and did it bolt on nicely?
7 - Can I remove the lighting wiring harness with no issues?
8 - Is that a map switch mounted on my coolant hose? I thought I remembered reading about it, but not sure. If so, where can I learn more about it.
That's all for now, i'm sure as I get further torn down, I will find more stuff.
