twowheels
Active member
Hey guys, back from the hospital and encouraged - it seems like my little girl has chosen to fight for it and she looks to be making measurable gains. Keep praying though, we're not out of the woods yet. Wait, I should use a different analogy, because after this week I can't wait to get back in the woods.
As to the axle, yes the YZ would be aesthetically preferred, but the way I measured it in order to have adequate clearance inside the brake side lug I needed to use the WR axle. The brake side lug isn't bored straight through, and you can run into an issue with the shoulder just beyond the axle threads bottoming out on the fork lug. This would be an issue in that the hub could essentially float laterally instead of being trapped as it should be on the axle.
The thought crossed my mind to attempt to machine the axle, but then the litigation side of my brain took over. Look inside an axle and you'll see a bunch of steps and I wasn't confident in the integrity of the part if I machined it down just aft of the threads. Lopping off the other side would have eliminated the internal hex - certainly an opportunity if you wanted to take it, but lately I've been mulling over threading in the axle from the right leg (non-brake side) as a means to to improve alignment. If the CRF axle works and looks better, by all means
The spacers themselves were hand-spun and then hard-coated (not really a coating, but actually an oxidation process) to levels that the US military finds acceptable. Hopefully they are tough enough for GasGas use
Let me know how they work out.
